Battle Born Offroad
Hey All!!! Offroad season is upon us and we know you are eager to hit the trail! If you are in the market for the one of the best lift kits on the market for our 4Runners, then you have to check out the Icon Stage 2 Tubular Kit. The kits features extended travel coilovers, up to 3.5" of lift and Icon's new Patented Delta Joint Upper Control Arms!!! We have this kit ready to go with no wait time!!! Click the link below to order or shoot us a message if you need any help!
CLICK HERE TO ORDER YOUR KIT TODAY!! FREE SHIPPING
This ICON Stage 2 suspension system for the 2010-UP Toyota 4Runner uses the same components as the Stage 1 system with a few simple changes and additions. The 2.5 Series coilover shocks used in this system are the Extended Travel version, offering increased wheel travel that will enhance your on and off-road performance even more so than the standard travel units. Since these shocks do provide more suspension travel, they require the use of an ICON upper control arm.
This system features upper control arms with ICON's patent pending Delta Joint. The Delta Joint is a heavy duty high angle ball joint that combines the durability of a ball joint with the performance characteristics of a traditional uniball. While the industry standard uniball does a great job of allowing the control arms of a vehicle to articulate with little bind, they do have an inherent weakness that leaves more to be desired when used in a daily driven application - exposure to the elements. The Delta Joint features a zinc plated housing providing the first layer of corrosion resistance, while a tough grease seal keeps potentially harmful elements out of the inner workings of the joint. Metal on metal construction and a greasable design increase the longevity of the Delta Joint while at the same time allowing for noise-free operation. What makes the Delta Joint unique is that it brings the best of both worlds to ICON upper control arms with features that make it more robust than a uniball, and at the same time capable of greater angularity than a typical ball joint.
TECH INFO:
KDSS Equipped vehicles require 54200 Rear Adjustable Track Bar
Click Here to Order your Track Bar if your vehicle has KDSS. Ships FREE
WHEEL & TIRE FITMENT INFO:
OEM Wheels & Tires: Yes
Aftermarket Wheels: 8-8.5 Wide, 4.75 Backspace
Aftermarket Tires: 33 x 11.25
(Larger tires may fit but fender trimming and modifications will be required)
SYSTEM COMPONENTS:
58647 (QTY.1) | 10-UP 4RUNNER EXT TRAVEL 2.5 SERIES IR COILOVER KIT
58451DJ (QTY.1) | 03-UP 4RUNNER TUBULAR DELTA JOINT UCA KIT
52700 (QTY.1) | 07-UP FJ/03-UP 4RUNNER REAR 2" SPRING KIT
56505 (QTY.2) | 03-UP 4 RUNNER 1-3 REAR 2.0 ALUMINUM SERIES IR SHOCK
