ICON Vehicle Dynamics Alloy Wheels
Developed by ICON Vehicle Dynamics (manufacturers of industry-leading performance suspension systems and shock absorbers) ICON Alloys was established with an objective to provide the off-road market quality wheels built with precision, performance, and strength in mind. Time after time in the development of suspension components the ICON R&D team ran into clearance, fitment, and steering geometry issues that limited the drivability and performance of a given vehicle. As this trend continued, the idea of manufacturing a line of wheels with the “form follows function” approach made more and more sense, and off to the drawing board it was…
PRECISION – Application-specific dimensions optimize vehicle dynamics and tire clearance for many of today’s most popular vehicles.
PERFORMANCE – Engineered to reduce unsprung weight and rotating mass for increased vehicle performance both on and off-road.
STRENGTH – Aluminum alloy construction provides high-strength properties that are well suited for heavy off-road abuse.​
The ICON Alloys 'SIX SPEED' is here!​
Shift into top gear with the ICON Alloys SIX SPEED! With a bold look and and "ICON-optimized" dimensions, these wheels will increase both the form and function of your Jeep, truck, or SUV. Staying true to the ICON Alloys approach, the SIX SPEED has been engineered to maximize caliper clearance and optimize wheel position for un-hindered suspension travel and steering function. Backspace dimensions and wheel offset have been strategically developed to reduce scrub radius, improving all-around handling and ride quality and making a set of these wheels the perfect complement to an ICON Vehicle Dynamics suspension system.​
Available in Satin Black, Gunmetal, and Machined - Which finish would you choose?
#1417858347GM Size:17x8.5 6x5.5" BS 4.75" 0mm Gun Metal $241.49 each
#1417858347MB Size: 17x8.5 Bolt Pattern 6x5.5 BS 4.75" 0mm Satin Black/Machine Finished $230.99 each
#1417858347SB Size: 17x8.5 Bolt Pattern 6x5.5 BS 4.75" 0mm Satin Black $230.99 each
ICON Alloys ‘ALPHA’ : A potent blend of on-road looks and off-road capability, the ALPHA is aimed to increase both the form and function of your Jeep, truck, or SUV. Staying true to the ICON Alloys approach, the ALPHA has been engineered to maximize caliper clearance and optimize wheel position for full suspension travel and steering function. Backspace dimensions and wheel offset have been strategically developed to reduce scrub radius, improving all-around handling and ride quality and making a set of these wheels the perfect complement to an ICON Vehicle Dynamics suspension system.
Available in Satin Black, Gunmetal, and Machined - Which finish would you choose?​
#1217858347GM 17x8.5" 6x5.5 BS 4.75" 0MM Gun Metal $241.49 each
#11217858347MB 17x8.5" 6x5.5 BS 4.75" 0MM BLACK/MACHINED $230.99 each
#11217858347MB 17x8.5" 6x5.5 BS 4.75" 0MM Satin BLACK $230.99 each
ICON Alloys ‘SHIELD’ : Proper fit and function, the SHIELD has been engineered to maximize caliper clearance and optimize wheel position for un-hindered suspension travel and steering function. With backspace dimensions developed specifically for Toyota and Jeep applications, a solid set of build features, proven strength, and looks that stand out from the rest, the SHIELD has you covered.
Available in Satin Black and Machined - Which finish would you choose?
#1017858347SB 17x8.5" 6x5.5 BS 4.75" 0mm BLACK $230.99
#1017858347MB 17x8.5" 6x5.5 BS 4.75" 0mm BLACK/MACHINED $230.99​
ICON Wheels are STRONG and LOOK Great when completing your ICON Suspension!!​
Please CONTACT us for more info and shipping for a SET of 4!​
DionicioLives
