idel at 2500
19904x4mike
hey evryone me again my other problem with my yota is that my rpms are high and stay high now the last time i drove it like 3 months aago the rpms would be at about 25to 2800 when the truck ws on park then when i popped it into drive it wold go down to about 1000 rpm..
now.. when i start it up it goes up to about 3000 rpm and since i hve no brakes at the moment im not gona put it into drive to see if the rpms drop...
if nyone could hlp with this problem id appreciate it
Have you tried adjusting your idle (on the throttle body 2 nuts) or you could have a vaccuum leak or you could have an electronic problem such as a tps (throttle position sensor)
Start with trying to adjust the idle
Than get a vaccuum tester and test the vaccuum system
carry on from there
