idle issue P0505
patriot54
History:
While on the highway my engine sucked in a PVC cap I had on the intake tube and it shifted the valve in my TB so my truck idled at 3500 rpm. I got a used throttle body and swapped them out. That fixed the 3500 rpm idle, but....
Now I am getting a code of P0505. I never got this code before. So I took the original IAC valve off and put it on the replacement TB, but I still get the same code and it idles low/ rough. Any idea why it would just start giving this code when it never did before?
That's a weird one for sure, did you clean the IAC before you swapped? I'd look up what voltage you should see at the IAC plug and see if you're getting an ECU signal at all.
