prodigy2k7
22RE '86 4runner (non turbo)
Okay well I finished putting on new head, pain in the.... anyways, it runs rough when idle, if i kick it up to 2K RPMs it sounds great..
I guess most cars do...
if im at 12 degrees it runs better at 12 degrees than when its at 5 degrees. What should the degrees BTDC be?
Im also messing with the idle screw with no luck...
plz sum1 help
Edit: Also with the "T" connector shorted, it seems to idle even rougher, it slows down. In the past I dont remember much of a difference in idle speed when timing it with T connector shorted.
Also since we removed the throttle cable, I was thinking that maybe it was too loose, but I think thats not the case, shouldnt it run idle fine when the throttle "butterfly" is fully closed? (or having the cable disconnected?)
Plz someone input!
plz sum1 help
Plz someone input!
