If you have Icon front coilovers please help
05Rrunner
4th or 5th gen Can you please measure how wide the coil is. Like if you had to put the coil in a box. Icon calls them 2 1/2" but my factory are like 4 1/2" now.
If you go up to your wheel wheel and just hold a tape measure across and try to judge how wide they are in the coil bucket. I figure they must be bigger around or longer because you have to move the sway bar forward.
Thanks for any help.
OP, umm are you confused? The coil spring yes is about 4.5".. A coilover spring is going to be about 2.5" in diameter, that is correct...
I'm not confused at all , but I think you are. Thanks to helpful member toyo we know A 2 1/2" coil over is just under 4 1/2" around or wide. Coil wire diameter is another mater. The 2 1/2 " is the shock body not counting the coil. I called icon twice for this info and they could not help me.
Yes, when dealing with "race car" type coils, the diameter is measured by the inside diameter -
2 1/2" springs could be 3 1/2" or even 4 or more depending on the thickness of the wire they are made from.
2007T4RunnerSport
