Hi, I bought a 1999 4runner 2wd automatic 6cyl. with 130k miles on it
I am getting like 12mpg 13 if I am lucky and drive mostly highway.
I replaced the o2 sensors (both) thermostat got oil change fill it up with injector cleaner every fill up, bosch platinum dual prong spark plugs...and no difference in the mpg
My mechanic said its most probably due to a pressure loss in the fuel injectors. I told him that when I start my car after being off for many hours, when I turn the ignition, it spins 4 or 5 times before it turns on. My air intake filter is clean, and all I have left to do is replace or really clean out the injectors and get a new fuel filter.
My sister has the same car but hers gets like 20-21 mpg, and her ignition turns on on the first click
What do I do?
I have read these forums (awesome place) and most people say slow down, clean MAF syntethic oil, tire pressure, but its not normal to get 12mpg on a 6cyl 2wd 4runner.
Also, I only can fill up 14gal in my tank, is that normal?
Should I replace my injectors? get new spark plug wires? Its time to get new tires, what should I get?
Thank so much for your advice, anything will help from all you 4runner guru's
What do I do?
