Important 3rd Gen car audio and alarm info
Rhoov1
This is a break down of the wire info for car audio and alarm installs in the 1996-2002 3rd Gen 4Runners. ALL WIRES MUST BE TESTED AND VERIFIED BEFORE HOOKING INTO THEM. USE A DMM (digital multi meter) OR AIRBAG SAFE TEST LIGHT TO VERIFY ALL WIRES. I TAKE NO RESPONSIBILITY FOR ANY DAMAGE TO ANYONES VEHICLE! THESE WIRE COLORS AND LOCATIONS ARE FOR REFERENCE ONLY.
1996-2002 Audio
Accessory 12Volt: Grey
Constant 12Volt: Blue/Yellow srtipe
Chassis Ground: Brown
Power Antenna: Black/White stripe*
Amp Remote: Pink/Blue Stripe*
Illumination: Green
Dimmer: White/Green stripe
Left Front Speaker +: Pink
Left Front Speaker - : Purple
Right Front Speaker + : Light Green
Right Front Speaker - : Blue
Left Rear Speaker + : Black
Left Rear Speaker - : Yellow
Right Rear Speaker + : Red
Right Rear Speaker - : White
Vehicle Speed Sense : Green/Orange stripe 1996 (A/T)= Pin #8 of 22 pin plug at ECU (Behind Glovebox)
Green/Orange stripe 1996 (M/T)= Pin #9 of 22 pin plug at ECU (Behind Glovebox)
Green/Orange stripe 1997 (A/T)= Pin #12 of 22 pin plug at ECU (Behing Glovebox)
Green/Orange stripe 1997 (M/T)= Pin #8 of 22 pin plug at ECU (Behind Glovebox)
Green/Orange stripe 1998 (All)= Pin #8 of 22 pin plug at ECU (Behind Glovebox)
Green/Orange stripe 1999-2002 (All) = Pin #6 of 22 pin plug at ECU (Behind Glovebox)
Reverse Light + : 1996-1998 White/Blue stripe Pin #1 or #4 of 11 pin plug on back of dash panel.
1999-2000 Red/Yellow stripe Pin #1 or #4 of 11 pin plug on back of dash panel
2001-2002 White/Blue stripe Pin #1 or #4 of 11 pin plug on back of dash panel
Parking Brake - : 1996-1998 Green/White stripe at parking brake switch
1999-2002 Red/White stripe at parking brake switch
Brake Light + : 1996-2002 Green/White stripe Pin #10 of 22 pin plug in drivers kick panel behind cover plate
* Both wires Black/White and Pink/Blue connect to the power antenna.
15 amp fuse labeled "ACC" in drivers side dash panel and 15 amp fuse labeled "Dome" under hood control the Stereo System. ACC has power only when the key is on and Dome has power at all times.
FOR ALL YEARS 1996 - 2002
--- IF the vehicle has 4 speakers ( without the tweeters in the front doors ) there is no factory amplifier.
--- IF the vehicle has 6 speakers ( with the tweeters in the front doors ) there is a factory amplifier.
--- Factory amplifier is located directly below and behind the radio mounted to the dash substrate with 2 10mm bolts.
---Factory radio brackets are best to use to mount the new radio but a dash kit is available. If factory brackets are used, a storage pocket is also available if a single DIN radio is installed and no pocket was available from the factory.
--- Metra Electronics #88-00-8000 Toyota Pocket
Metra Electronics # 99-9101 Toyota Multi kit
Metra Electronics # 99-8104 Toyota Pickup / 4Runner Kit
Metra Electronics # 70-1761 Toyota Harness
Metra Electronics #70-8112 Toyota Amp Intregration Harness
Metra Electronics # 71-1761 Toyota OEM Harness
Metra Electronics # 40-UV43 and 40GM10 Male to 2 Female Motorola antenna Y adaptor and GM antenna adaptor ( for adding the rear glass antenna to the front AM/FM antenna )
Speaker Sizes - Front Doors = 6.5" with a mounting depth of 2.5"
Front Doors = 1" with a mounting depth of 1"
Rear Doors = 5.25 with a mounting depth of 2.5"
--- There are 2 Antennas used in the 4Runners. a powered antenna on the passenger side fender and an in glass antenna in the Rear quarter glass. The front Power antenna can be replaced with a Non powered antenna from a Toyota Tacoma. (See Tacoma Whip Mod Thread )
Keyless Entry/ Alarm/ Remote Start Info
1996-1997
12V: White - White/Red + Ignition Harness
Starter: Black + Ignition Harness
Ignition: Black/Yellow + Ignition Harness
Second Ignition: Black/Yellow or Black/Red + Ignition Harness
Accessory: Blue/Red + Ignition Harness
Power Lock: Red/White - 10 pin plug, left of fusebox
Power Unlock: Red/yellow - 10 pin plug, left of fusebox
Parking Lights: Green + White plug, front of fusebox
Parking Lights: Red/White - Steering column
Door Trigger: Black/White - Driver Kick panel, harness to rear
Dome light supervision: USE DOOR TRIGGER
Trunk/Hatch pin: Red/White - Driver Kick Panel, Harness to rear
Tachometer: Black ac Ignitor or Data plug*
Brake Wire: Green/White + Brake Switch
Horn Trigger: Green/Red - Steering Column
* Ignitor is on passenger side fender well. Diagnostic Connector is on drivers side top of motor.
1998
same as 1996-1997 but Starter could be Green/Black or Black + ignition harness
1999-2002
12Volt: White/Red (30 Amp) + Ignition Switch, White 8 pin plug, pin 7
Starter: Green/Black or Black + Ignition Switich, White 8 pin plug, pin 8
Ignition: Black/Red + Ignition Switch, White 8 pin plug, pin 6
Second Ignition: Black/Yellow + Ignition Switch, White 8 pin plug, pin 4
Accessory: Blue/Red + Ignition Switch, White 8 pin plug, pin 3
Keysense: Yellow/red - Key Switch, White 2 pin plug, pin 2
Power Lock: Red/White - Driver Kick Door Harness
Power Unlock: Red - Driver Kick Door Harness
Lock Motor: Blue/White 5wire Driver Kick blue 12 pin plug
Unlock Motor: Pink/Green 5wire Driver Kick blue 12 pin plug
Parking Lights: Green + Driver kick, harness to rear
Parking Lights: Red/White - Headlight Switch
Hazards: ( Same as turn signals )
Turn Signal Left: Grey/Black + Turn Signal Switch
Turn Signal Right: Green/Yellow + Turn Signal Switch
Reverse Light: Red/Yellow + Driver Kick, Harness to rear
Door Trigger: Light Green/Black - Dash fuse box, rear, white 8 pin plug pin 7
Domelight Supervision: ( Use Door Trigger )
Trunk/Hatch Pin: Light Green/Red - Driver Kick, white 22 pin plug
Hood Pin: Green/Orange - Driver Fusebox, white 8 pin plug pin 7
Trunk/Hatch Release: ( Locks and unlocks with doors )
Factory Alarm Arm: Brown/White (driver door key lock) - Driver Kick Door harness
Factory Alarm Disarm: Blue/Black (key unlock) and Red/Blue (detection) Double - Driver Kick, door harness
Disarm no unlock: ( Use Keysense )
Tachometer: Black ac Diagnostic connector Drivers side of engine black 23 pin plug pin 19
Brake Wire: Green/White + Brake Switch or driver Kick, harness to rear
Parking Break: Green/White or Red/White - Parking Brake Switch
Horn Trigger: Green/Red - Dash Fuse Box, white 23 pin plug pin 1
Reverse Light + :
Where is the "back of dash panel" plug for the reverse light positive? Under the bezel by the shifter? I'm confused
Check the drivers kick panel, wire harness heading to the rear, red with yellow stripe.
Thanks I will try that
Trying to hook up my new double din touch screen and I need to connect to brake switch and reverse light - found out when I was 90% done oops
Great information. This is the most extensive list I have found and I enabled me to finish my remote start install. The problem child was the parking light wire and this info led me right to it. Thank you
