Antpwr
Alright, here is the story, i'm not new to toyota or off roading, have had a few 85 yotas on 36's and recently an 02 Tacoma double cab with 9" of susp. lift and 38.5 claws, (no body lift of cutting), i now own a 99 4runner limited, and have been looking at lift options, i want at least 3 plus, more hoping for 6", i think i have figured it out for the front at least, some minor fabing, no cutting or body lift wanted though, the problem seems to be the rear, i have heard that LC80 front springs, can get a 5" lift on the 4rnr rear, and that OME 851 will get 6", is any of this true, and i want to know if anyone has got an idea where the hell to pick up an adjustable pan hard bar, and adjustable links, as at that height the links will pull the axle forward more, and any ideas on how to safely get the 6" height all the way around would be helpful, any ideas are good ideas. The end goal, to run a set of 35" tires, either Baja Claws (had great luck with them) or something similar, thanks and appreciate the feedback.
