info needed converting from 319mm discs to 338mm
03V84R
Need to upgrade to the larger discs/calipers on my SR5. Whats needed? Obviously new calipers/discs/pads . Backing plates,hardware?? etc..
thanks
If you get everything new, it should come with hardware. I did mine last saturday and kept the same backing plates. Some people cut the backing plate. I bent mine to fit. Instead of having that outward curve. I bent it straight.
johnnya
