Info on rear end
ddnww
Can someone with an 86-95 measure the width from back of drum to back of drum on other side for me please?
Also do these years models that had the thicker rear end on the v6/ turbo Toyota/ pickup/ 4runner have the same width as the 4 cyl rear end?
V6 & Turbo diffs have 4 spiders gears in the rear third
4 Cyl diffs have 2 spider gears.
I don't actually get what you mean thicker rear end..been messing with these POS's for 34 years
Below pulled from Pirate FAQ
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, SA Hubs
58.25" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, IFS Hubs
63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers
'86-95 IFS front end is about 58.5" wide
'93-98 T100 IFS front end is about 65" wide
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
Thank you, ok so the difference is 2 pinion vs 4 pinion on the 4cyl to 6 cyl rear ends.
I know the 86-95 is 58 inches wide at the flangeto flange aka wheel mounting surface, but I need the measurement from the back plate to back plate, I believe it should be about 50 inches.
erinobr2000
