RL Lemke
To keep a disk brake caliper in good shape the brake fluid must be regularly flushed to remove absorbed moisture. In wet climates this would be annually. Look at Subaru and motorcycle manufacturer schedules and you will see annual flushing.
In addition, one should have the brake pad retaining pins replaced. Cheap insurance that the pads won't get caught on corroded pins. Cheap insurance.
When new, I had Speed Bleeders installed on each caliper.
