Inner Tie Rods
dbfoerster
2006 Sport/V8 with a Toytec lift and 33's.
This summer I did a tough trail and had to replace my itr for the first time. Last week I went to Moab and rode the White Rim and then did Elephant Hill. Now the itr are shot again.
I bought the ones recommended by Napa, but is there something else that is better or is there a mod I can do to prevent this from happening again?
Help:(
I don't know what kind you're using from napa, but mine was leaking about 8 months ago and I replaced it myself with a Moog tie rod end. Moog has made amazing products which sometimes last way longer than even factory products. I'd go with them, you can find them online at advanced auto parts, and also, if you just google advance auto parts coupons, you can put in a coupon code when checking out and it will save you a lot of money! Then you can just go pick it up there! Hope this helps! :D
Help:(
your inner tie Rod is failing? is it breaking or what's failing? what conditions are causing it to fail..
if its the tie rod end link then x2 on moog products they're pretty tough with good qaulity boots
