jeober
I've installed high wattage 9005/6 bulbs, ordered from JC Whitney. These were about $12 each. I went with the clear glass bulbs, not any blue tinted - I just want maximum light on the road.
I used relays for each high / low beam with 14 awg wiring fused from B+ and I totally bypass the OEM lamp wiring to minimize voltage drops. I bought separate 9005/9006 male sockets from the local autoparts store. The relay coils are controlled by the original lamp connections on one side - I did destroy one pair of bulbs to salvage the female sockets so the new harness plugs together and I could easily restore to OE if necessary. The two unused original lamp connections were plugged with dielectric grease to minimize corrosion in the terminals.
Lighting is nice as expected - Low beams are bright, white, and with good cut-offs. High beams are powerful - 360 watts!
