if you guys are wondering how the Bilstein 6112's look at top notch
here you go
settled a bit
with 265/65 R18 tires, there's only about an 1 1/2' of space between UCA and tire so i may need spacers for wider tire.
its sitting nose high because i haven't done the back yet... fronts killed my back, these are a pain in the a$$ to install, assembling them took forever... because those springs are strong! took 2 guys to hold in place while i tighten the top nut. (very dangerous if it slipped off the spring mount machine)
going with with Toytec Superflex and Bilstein 5100 shocks for the rear.
old vs. new rear springs
install was super easy
final result!
big difference from the daystars 2.5 1.5 spacer kit...
here you go
settled a bit
final result!
