Installing StopTech Braided Steel Brake Lines
Anyone know the stop tech part number for rear stainless brake lines? There are a left/right that run along the rear axel. One of mine is leaking.
I have 199mm upgrade on my 99 4runner. Need to replace front and rear brake lines with stoptech stainless.
Front is 950.44014???
Rear ??
Any feedback is greatly appreciated
I thought only the 2001-2002 came with the two rear lines. And that the 1996-2000 came with one line on the pumpkin.
Or are you referring to the hard lines?
Rear ??
not sure if StopTech makes them, but here are the Toyota part numbers:
RH - 47325-35282
LH - 47326-35062
Reviving this old thread. I'm looking to replace the Union Tee fitting that the rear soft line goes to and left and right hard lines go out from that. Would any M10x1.0 break line Tee fitting work? I guess I'm not sure if the end of the soft hose that goes into the Tee has the double flare like all the hard lines. It makes sense that it would.. I'm building new hard lines that go from the Tee fitting to the wheel cylinders and would like to source all the parts before I open the system up. Also replacing the wheel cylinders and the soft line.
Thanks.
