Instrument stepper motor replacement
Toyoter
Junior Member
Hello,
Does anyone have a tutorial on replacing the stepper motor(s)? I just need the info once the cluster is out. I don't know if the motors are plug and play or if you have to desolder and solder.
Thank you.
[MENTION=136768]Toyoter[/MENTION] did you ever get this repaired? Resurrecting this thread cuz I need to repair my speedometer and I’ve found some helpful info.
To answer your question or if anyone else is searching for this and wanting to know. Yes it does require soldering. Scott Lam at “The Track Ahead” does a good write up on it here:
Speedometer Stopped Working: 4th Gen Toyota 4Runner - The Track Ahead
But if your not familiar soldering on circuit boards I wouldn’t attempt it unless your prepared to make a mistake and have to replace the whole cluster.
As Scott mentions you can buy the stepper motor here:
2003-2013 Toyota 6S Stepper Motor | Tanin Auto Electronix
They also offer a repair service if you want to send your cluster in but it’s a bit pricey at $175 or buy a completely refurbished cluster for $310 at the time of this post.
