Intake suggestions
Akmambarunner
I'm looking to purchase a CAI. Having a tough time choosing between S&B and AFE momentum. Any help towards which one is better as far as gains? S&B is ~$100 cheaper overall. I will also likely purchase the AFE Throttle Body Spacer. Looking for suggestions/help choosing which one. Thanks
Take it from someone who came from the Mustang world, save your money and stick with stock. It's well documented that intake air temps are cooler with closed element air boxes vs open element intakes. It's also well documented that the vast majority of power/torque increase in a CAI/tune combo comes from the tune, not the intake. Finally, in a naturally aspirated application, the stock air box is and never will be restrictive. An aftermarket intake that doesn't require a tune and costs several hundred dollars may net you 5hp and 5lb-ft at the wheels. You'll never notice it.
If you're interested in bumping your power and torque numbers, leave your stock air box and just get a tune. The absolute only time an aftermarket intake would become a good idea (read: still not necessary for most people) is in forced induction applications, where a stock soft rubber intake tube could collapse with enough boost boost, whereas a rigid plastic one won't.
Thank You for the info. The S&B actually has enclosed air box (plexiglass) which I find unique compared to other intakes.
Again, you would be paying $300 for what is essentially a fancy OEM box with an oiled filter, which doesn't filter as well as a regular paper or dry media reusable would. Keep the stock air box and get a tune, your money would be much better spent.
Just get the afe dry filter for the stock airbox. I had the actual afe cold air for about 2 weeks then sold it. It only sounded cool at high rpms, that's about it. Went back to stock and purchased the afe dry filter for the stock airbox and never looked back.
Thanks guys really appreciate your input and expertise. With that being said, what Tunes do you suggest. Considering the Dry Air filter and a Tune currently.
I have the AFE Momentum GT and the AFE TB spacer and I love them. Combined with a Borla Touring Cat-Back and my truck has nice get up and go without any throttle tricking aids.
In my experience, you'll need a hi-flow exhaust (Borla, Gibson, etc..) to go along with the CAI to really get the best results. I have the AFE Momentum GT and ran it with stock exhaust at first, then added a Borla. The difference the two make combined is very noticeable. Separately, not so much...
This so true. I run the k/n intake and magnum dual exhaust on my Tundra but I also went and had it custom tuned on the dyno. 12 years later the truck is still faster than a new stock Tundra by far and runs like new. Our 2018 trd 4 runner is stock but the older 96 4 runner has the same setup.
Perfect because I just installed the Borla exhaust this weekend.
seltzernator
