interior map and dome lens replacements
Hi, Im trying to find replacements for dome and map light lenses/covers. My ArcLights LED install required some cutting and drilling and it turned out rather sloppy. Does anyone know if its possible to buy just the clear plastic light covers? Thank you
Did you try calling a dealer? They might be able to find out pretty quickly for you.
There's a couple parts listed here, but I don't see anything just for the lens, but rather the light assembly.
Genuine OEM Interior Trim - Roof Parts for 2018 Toyota 4Runner TRD Off-Road - Olathe Toyota Parts Center
I just installed the arc light White/Red led in the cargo lid, had to drill the lens for the push button. I wanted a pair of replacement lens in case the drilled ones crack.
The lens is not sold separately, you have to buy the whole assembly.
I purchased two new lights for about 21 bucks each.
I must say these new led are super bright even in the red.
I may just use one OEM and one acr light so I have more light options.
I was not able to find the lenses only. Ebay is probably the best bet for finding a cheap set of replacements. Or do you live near a junk yard?
DionicioLives
