Interior swap
bay_area4runner
so I can possibly get my hands on. A doner vehicle, the interior is pretty clean and the driver seat is the only thing that is ripped but can be replaced.
Has anyone on here done a full interior swap? I'm going from a sport edition to a limited edition, from grey to tan. Also the seats are heated, most likely I'll have to figure out the wiring and also the will the temperature control be able to swap right into Each Other?
Can anyone help.
I've done it. Wiring the seats is simple. I think the wiring colors are posted somewhere. You'll just have to tap in somewhere for power.
The one thing that isn't reusable are the 4 clips that hold the headliner up, so you'll have to order new ones. Everything comes apart and together pretty easily. Most things start at the bottom and you work your way up. Just feel out each panel for clips. They are pretty strong, so they don't break easily. Make sure to drop the column down to get the cluster and dashboard out easier.
You're pretty much stick with whatever heater controls your truck came with, they are too different to mess with unfortunately.
If you run into anything along the way just let me know.
Sent from my Z981 using Tapatalk
What exactly are you asking for help on? Your post isn't clear what you're asking about.
The HVAC controls depend on the year of the vehicles, but just keep what you have- it will fit in the tan dash just the same.
Seat heaters should be an easy retrofit since you'll have all the wiring [emoji1360]
"Easy" is relative, especially since we have no idea of your abilities from your vague post.
seltzernator
