Interior Trim Color 06 Limited
Texas8668
I am buying the interior rear view mirror assembly pieces for my 4R and there are two, listed by color. Stone or Fawn.
Is there a way to tell visually which color my interior is so that I buy the correct/matching color pieces. thanks!
Easy way to check is on the label by the driver's door jamb. On the lower right side of the label you'll find C/TR and then something like 8R3/FG42. Look at the code after the /
FG12 and FG42 are found on the SR5's (12 for stone and 42 for taupe.) FH13 is for the Sport Editions with the dark charcoal interior. LB12 and LB42 are found with the Limiteds (12 for stone, 42 for taupe).
Hope that helps. Your pictures look like the Stone interior to me, which should be FG12.
This should help. Welcome to the forum. A quick google search would have pointed you right to this.
I only used the alternate search in google (searching the 4th gen thread directly) out of habit and didn't even think to just search google. my bad all. thanks for the prompt reply. order placed.
Jhunt
