Intermittant Pwr Door Locks - Dome Light
murph73
Please help.
I'm new to this forum and have done a good bit of searching on the topic but have not found the answer. I've seen several posts that indicate the rear dome light does not light when in the "door" position and the door is open. There seems to be a mysterious rear door sensor which no one can find that may be the culprit. I have nearly the entire rear interior removed and have been unable to find the sensor. I'm not tremendously concerned about the light, but I believe it is affecting my aftermarket alarm.
Alarm problem: doors do not always lock/unlock with the remote sensor nor by turning the key on or off in the ignition. Locks work fine when using the trigger on the door.
Any thoughts, ideas, suggestions much appreciated!!
