iPod using USA Spec on base audio unit 05
markman100
Just got my first iPod, the Nano. This thing is an amazing piece of engineering. I've read some interesting things here about using the USA Spec unit with the higher end factory audio systems. My '05 runner has the base unit. Will it work with it? What are some specifics? How do you change playlists? Will it display text?
I have the USA-Spec pa11-toy. I installed it with a Scion headunit but it works the same with the toyota base head unit. There are two setting on the pa11. There is playlist mode and direct mode. Playlist mode makes it so you can control 5 playlists as if they were discs in a cd changer. However, it locks the ipod so you can only use these 5 playlists. I chose to put the pa11 in direct mode. This allows me to control the ipod by using the ipod buttons. It also lets me skip/ff a track through the headunit and steering wheel controls. This way, I have access to all of my songs. You have to choose which setting (Playlist or Direct) when you install the pa11 so you cannot switch it during use. It will not display text either way. It will only show up on the headunit as if it is a cd changer.
Thanks for the great information. Is there anyway to hack the USA Spec so you can extend the switch? It would be nice to keep your options open until you figure out how you are going to use it. Or is the switching method (as in DIP switches) too embedded in the box?
Sounds like the direct method is the way to go for me.
Where does the iPod connector come out? Can I just fish it out from under the dashboard?
I see in your photo in the other thread that some text is displayed on your head unit. Is this because you have the '06 Scion unit or is the text in the photo from a MP3 cd?:confused:
it looks like the pa11-toy is the way to go. Will this work with the JBL single disc 10 speaker unit as well?
