Is Armorall Bad???
the_josh
i hear armorall is bad for your interior, is this true?
what does everyone use to shine up their interior beside armorall???
Armor All has been reformulated within the past few years and is now water based. From what I hear, it's supposed to be safe now although some people still think it is a bit too shiny.
I use a bunch of products on my interior, 303 Aerospace protectant, Einszett Tiefenpflegar and Einszett Cockpit Premium to name a few. All of these products are good with the last one being more of an "interior quick detailer".
Vinylex is also pretty good stuff for interior plastics (not clear plastics though). It gives a nice satin like finish.
You want to stay away from anything that is high in silicon. It will dry out plastics, which leads to fading and cracking.
It's great stuff if you don't use it :) j/k
Their Matte finish isn't that shiney. Just my opinion though.
Interior
Leather Seats
classic-motoring_1792_13950383
Lexol Leather Cleaner
classic-motoring_1792_14039251
Leather Conditioner
Vinyl and Plastic
classic-motoring_1792_19378482
Vinylex
Interior Kit
classic-motoring_1792_10078075
:guitar2:
All of the above ....
Plus use microfiber towels.
Use a gentle non-ammonia automotive window cleaner (or plain water).
I have been using Armoral for years and a simple Bounty paper-towel and I never had a problem. The only thing I can suggest not to do which is motorcycle related is if you use it on your seat, make sure you do not ride it the same day. I did that, and my butt was sliding all over the place. Good thing the roads were smooth.
I actually just use a bucket of clean water, and a wet and dry towel.
I wipe everything down, then dry it. I don't really want everything inside to be super shiney and greasy, just nice and clean looking.
Good old water works like a charm.
Armor all, and most other interior 'dressings' contains silicone disolates. This ingrediant is not only the equivalent to putting cooking grease in your hair to give it that 'natural healthy shine', but it's also 'addictive' for the interior of your car like a bad drug habit. In other words, when you apply it the first time, it looks great (if you like the 'glazed donut' look) once the stuff wears off, your plastic is slightly worse looking than before you even used it, so you use it again to get it looking good again. The cycle repeats with the plastic getting nastier and worse looking each time until it just starts to discolor and possibly even crack.
The easiest way to tell if a product contains silicone in it is to apply it to a piece of plastic or rubber, let it cure (give it maybe 10-15 minutes depending on how thick you layed it on), and then put a 'second coat' ontop of it. If the second coat makes it even shinier, then it has silicone in it... since silicone will 'stack' on top of dry silicone. Quality products will not 'stack' and will only appear as shiny as the first coat.
Another way to tell: silicone based products allow you to rub your finger along them and build up a thick residue (often times black, but sometimes clear). This also causes it to sometimes sling from your tires to your paint, and also gives interior plastic an often times almost permanent greasy feel.
Non-silicone based products generally give, at the most, a slightly 'wet' or slick feel that's actually usually anti-static (doesn't collect dust, unlike silicone which attracts it), but no residue will show up on your finger unless you just applied the stuff shortly before.
Good non-silicone based products are rare but can be found - mostly on the internet.
My favorite by far all around is 303 aerospace protectant. Meguires endurance (not the high-gloss version that's purple color, you want the standard version that's in the black bottle, as the purple contains silicone) is a good product for tires if you're looking for a quick fix at the store.
Zaino Bros. tire/interior dressing is another good option as well, and so is Lexol/vinylex.
Armorall, black magic, and so on all contain a whole lot of silicone.
