ok this is getting ridiculous.. first my setup in front
ome 884 springs
bilstein 5100 on lowest setting
light racing UCA
17x8 ATX mojave
285/70 duratrac
so today i got an alignment after the UCA went in..
problem? massive rubbing in the back of the wheel well on the body mount
basically adjusting the uca ball joint for positive caster does not move the wheel forward to give more clearance because it just moves the top of the pivot line backwards for more caster
setting the ball joint to maximum caster caused positive camber even at the most negative camber setting on the UCA.. so backed it of to 1 setting above center (position D)
now camber is perfect and caster at 2.0.. much better than before UCA which was +.9 camber and -.5 caster
but somehow the tires are rubbing worse than before on the body mount and no the tech did not back the cambolts way back.. only maybe .2 degree to even both sides after adjusting the uca
am i going to have to do a body mount chop? since 95% of forward adjustments on the lower control arm are gone on one side and 100% gone on the other.. the 5% was just used to bring both side even..
the lift is very even so i don't want to go any higher even though i could with the 5100s .. and i don't think lifting sky high is the answer to stop rubbing
are cambolts slightly different for every car? why is mine running out of adjustments forward when others have no rub on 285 even with a modest lift
the rub only happens at full lock while backing up.. but it's kinda scary since the tread gets caught on the mount and gets pulled until freed which can't be good..
sorry for the long post but this is getting outta hand..
anyone know a good place to do mount chop in so cal? seems liek that's my only option now.. will gladly pay member from forum to do it too
ome 884 springs
light racing UCA
17x8 ATX mojave
285/70 duratrac
