Is it possible for to overheat without any issues?
dallison
My wife got stuck in our 01 with almost 180k auto 4runner. It was 95 degrees, humid as hell, ac on full blast, 2 passengers, one large dog and all of their crap.
All was well last weekend when i drove it for an hour in the heat but with a lot less in it.
Can a vehicle just overheat with those conditions? She was running for about an hour and 20 minutes on mostly flat land but i am sure she was doing 70-80.
thanks
thanks
4Runners should never overheat. I've been in 100 degree weather, A/C on full blast pulling an Infiniti G20 up a 6% grade 20 mile canyon going 70 MPH and not overheated. My foot was to the floor most of the time. If it does overheat, you can warp/crack heads among other things. Toyota and Honda engines are sensitive to overheating.
No it shouldn't. Something is wrong. These trucks were rated to tow 5000lbs by Toyota, that's a lot more strain than your wife was putting on it.
That's what I had thought. AAA is towing it to the house, so hopefully i can mess with it over the weekend. I can always have them tow it to the dealer if needed.
She couldn't start it when it overheated, but it did when they got the truck back to the house.
I'll start with codes and the radiator cap. I'll check to make sure nothing is leaking out of the motor and check the oil to make sure it's not milky.
Maybe it's a thermostat or the advance auto radiator that i had purchased for it 4-6 years ago.
ouch. hopefully its not a headgasket.
if its survived 4-6 years, not sure, i feel like advance auto radiators die within the first 6 months or last. no idea though. but sounds like you will be able to figure it out if you have replaced the radiator in the past.
You're making some assumptions here...how to word this politely, hmmm....
You may have warped a head. Consider yourself lucky if you don't end up with an expensive repair either a head gasket with new head(s) or a new motor.
Really? 5k lbs?
Yep, for the V6. This is from the '99 Owner's Manual, p.144
https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxyYXlkb3VibGUzNjB8Z3g6MmExYjU0ZTQ3MjJkMWU3YQ
The total trailer weight (trailer weight plus its cargo load) must not exceed the following. Exceeding this weight is dangerous. If towing a trailer over 907 kg (2000lb.), it is necessary to use a sway control device with a sufficient capacity.
3RZ-FE engine
1587 kg (3500 lb.)
5VZ-FE engine
2267 kg (5000 lb.)
The gross combination weight (sum of your vehicle weight plus its load and the total trailer weight) must not exceed the following.
Two-wheel drive models
3RZ-FE engine
3447 kg (7600 lb.)
5VZ-FE engine
3992 kg (8800 lb.)
Four-wheel drive models
3RZ-FE engine
3583 kg (7900 lb.)
5VZ-FE engine
4173 kg (9200 lb.)
I doubt it's the weight. And to Yukon4runner it's not an assumption. A/C on full blast with 500 pounds in it isn't the reason. It would have overheated without that. Could be as simple as a fan clutch although doubtful if she was at speed without stop and go. Could be thermostat or radiator or just a slow fluid leak you didn't notice
Mine did the same thing over the weekend, over heat going up the 152 to SF on the 101. Had to turn the ac off, after that it was normal again. Never change then radiator or clutch fan. Timing and water pump at 115k
You said you have a scan gauge did your wife by chance see how hot the Water temp got or reached ? I have reached 216F from which I believe is very hot but usually run at 195, Although I have heard that that is operating temp (216) but then again I'm fully armored and whatnot. If the head gasket is fine and everything checks out id go ahead and replace the thermostat with a cooler one and jiggle valve at 6 o'clock (which i desperately need to do).
2001ATL
