You could wire up something like this:
https://www.qualitymobilevideo.com/bu508td.html
But why would you want to? Either it goes off with the vehicle or is constant on. I've seen plenty of vehicles now that have their headlights and/or interior lights on some kind of delay setup similar to this. I'm not a fan of these features. I get used to them then switch back to a vehicle that doesn't have it and I end up leaving my headlights on or something.
Thanks I'll look into it.
I want to install a dash cam. But all dash cam have a common problem that they often can not save the last video when the engine shuts off, some because the internal battery went bad due to heat, some because the internal capacitor does not contain enough power to save the last video. So if the car battery can provide power a little longer after engine shuts off it would be great.
You could also use a turbo timer - old school device that keeps the engine running for a set amount of time. Probably the easiest method (assuming you have a basic dash cam) but you would have to be ok with running the engine for a bit each time you arrive at your destination...
