Is it worth $25?
It's cheap, I'd give it a shot. I've used SRI's on other vehicles. If you live in a cooler area then I think it can be a +. If you live in a hot area, then SRI's notoriously take in warmer air thus hurting performance or at least negating any gains you would've had using it in a cooler climate.
If you want a better name, check K&N's intake kits.
It's more expensive, probably $200.
But they're CLAIMING 9.5HP increase. Obviously you need to take into account they're dynoing in optimal conditions. But at least K&N's has a heat shield, whereas yours does not.
I've read that the K&N FIPK nets a loss of HP.
neliconcept said:
get it.. take the pipe and dump the filter.. and hook it up to your deckplate modded airbox..
my opinion.
is the tube the correct length to make it all the way to my airbox?
While I don't dispute that there are intakes out there that result in this, I'd be very surprised if K&N's did. do you have a link? article?
sure. here is the link.
http://www.gadgetonline.com/AirInduction.htm#K&N Fuel Injection Performance Kit
keep in mind the car that is doing the dyno testing for this has a supercharger along with many other high performance drivetrain upgrades, but is in fact a 4Runner. Some engine setups just dont work well with certain parts and the yota 3400 is one of them.
