Is my t4r going to be level?
SaltwatersouL
im getting some ome springs and shocks for my 95 4runner, and im also puttung spacers in the back, ive read this should lift the rear around 2-3inches. are
bj spacers going to lift the front enough to be level with the back?
What other options are there for lifting the front end higher?
You dont need to start s new thread for stuff like this, just keep your old one going.
The next jump up from BJ Spacers is either a 4" IFS lift, or a long travel system like Total Chaos or Blazeland.
You can get 2" out of the BJ spacers. Get everything installed, and see how it sits. Then worry about getting it level. Your putting spacers on a stock spring, that Im assuming is a little saggy to start with. It should be about perfect.
Imf you have ADD front hubs, I would advise switching to a manual hub to save your CV life.
The OME springs plus spacers may give you more than 3", so with 2" BJ spacers up front you may sit a little higher in the rear, but you can always remove the rear spacers.
