Good luck with that. The farm lobby has so badly deceived the environmentalists & congress that they're the way to go, it's nearly all you can get.riverider said:More important to me is finding real 100% gas and not the 10%+ Ethanol junk.
slowteg97 said:i wouldnt suggest using regular in our trucks mostly cause alot of stations are now using 87 octane as reg instead of 89, and the 89 octane is now plus, and 91 is either super at sunoco and ultra is 93 or the 91 has been taken out. i noticed a difference of about 50 miles out of the tank when using 87 verses 89 and i would think with 91 or 93 i'd get alittle better. my average out of the tank is 385 total and when i ran reg 87 i got 330. needless to say it was the last time i ran regular and since im already use to paying almost 5bux a gallon for 87 reg paying 1.89 for plus is no biggy now.
03_4x4Runner said:I have only used 87 octane for 5.5 years other than several tanks to so if 91 helped anything. I cannot tell a difference. The engines use knock sensors so the computer will pull out timing etc. if there is detenation.
jharris2 said:My manual says:
"Fuel type:
Unleaded gasoline, Octane Rating 87
(Research Octane Number 91) or higher.
For improved vehicle performance, the
use of premium unleaded gasoline with
an Octane Rating of 91 (Research Octane
Number 96) or higher is recommended."
So premium is not required.
Yours probably says the same thing.
