Is there a way to use Hi-Lift Steel Jack on Limited T4R?
I agree with Brian. The hi lift isn't designed to be used "as a regular jack to work on a vehicle". It's not safe. It's design to be used for off road emergency. But I would never use a hi lift jack to jack up my 4runner and get under it. Only to change tires on side of the road, or few other things.
http://a.co/2T1cDxb
None of my jacks lift up my 3rd gen enough to change the wheel, is there a place to lift T4R with Hi-Lift Steel Jack ?
A Hi-Lift would be pretty much useless on plastic bumpers and side steps.
If your floor jack isn't tall enough to lift the frame of the truck you can lay a piece of 2x4 wood on the jack pad to gain some lift. You can also lift under a lower spot, like the rear diff or the front lower control arm.
Remember to support the vehicle safely with jack stands before attempting any repairs.
yes there is a way, you will need to buy the hi lift straps that hook onto your wheel, jack up the wheel and put a jack stand underneath your frame... remove the hi lift and change your wheel
I won't go under unless all wheels are chocked and it's sitting on firm blocks of wood in multiple locations.
That's how I roll too. And I'd avoid the hi lift as much as possible, except for off road emergency.. and even still, not really hot about it.
2001ATL
