Is this a good setup?
99 4runner sr5
After doing my research, i think im going to get the toytec 3 inch OME front and rear coil lift, with front diff drop. And Bilstein shocks all the way around. What do yall think about this setup, for weekend off road?
IMO....Don't get diff drop. It is not needed. You will get many opinions on that though. What kind of Bilsteins?
Rear- 5125
Front-5100
Sounds good. Other than diff drop. May want to look into e-brake bracket and adjustable panhard bar or panhard bracket, rear extended brake line, rear extended bump stops. I like my set up. Toytec adjustable coilovers on front, Sonoran Steel 1.2 kit rear.
To start, it is a good set up and you can add the rest later. Good luck!
if your gonna get the bilstien 5100s, dont get the tacoma ones, get the tundra ones, they have more range of adjustablity for better fine tuning
youre gonna love the lift!
oh and make sure you get an alignment once you install the lift ASAP!!
2001ATL
