I've had my '08 Urban Runner for five days now. I went out to some muddy roads the other day to test out the 4wd and locking differential to make sure that they worked appropriately. I did engage and disengage the 4hi, 4lo and center locking differential while test driving the vehicle but could not do much other than make sure they engaged and disengaged smoothly.
So here is what I am concerned is a major problem. I was trying to reverse up a steep muddy hill. The 4runner was in a position where the rear driver side wheel was almost completely off of the ground. I was in 4hi with the center differential locked. I was unable to reverse up the hill and the wheel that had no weight on it began to spin while the others were not. When this happened, I heard some awful slipping or grinding noises in the drive train. I immediately let off of the gas and stopped trying to back up. What was happening? I was under the impression that all four tires should have been locked together and that no one wheel would spin more than the others. Do I have a bad or slipping center differential?
If this is a major problem, I assume that the vehicle being 5 days old and certified pre-owned, the dealer should take care of it with little fuss.
Any thoughts?
Any thoughts?
