Is this everything I need for my lift?
Jcruze
So I'm pretty sure I know what lift setup I want. Originally I wanted to do the tundra front and lc 7 wrap rear after reading rickashay's write up about OME vs tundra lift. I'm looking for a lift that will be comfortable on road but still be able to take me where I want off road :) But after searching for a few weeks I haven't been able to find any good leads on the tundra or lc wraps.
I think now I want to keep the tundra adjustable 5100 shocks from rickashay's setup but use the ome 881 coils for the front and toytec's superflex springs for the back. I'm not planning on getting a front bumper anytime soon so I figure the 881's would be a little better then the eibach springs at keeping the ride quality comfortable on road.
Now would using the 5100's in the rear be a good setup for the superflex springs? Or does someone have a better shock suggestion for the rear?
All together everything I would need would be as follows:????
- Tundra Bilstein 5100's for the front and rear
- .75 bushings for the rear shocks
- OME 881 coils
- Superflex coils
- 1" differential drop
- tundra coil spring isolators
Do I need to order new top plates? And am I forgeting anything else?
If you happen to be running this setup please let me know how it rides :)
Its suggested you get 5125 for the rears with the super flex coils from what I understand.
If you're assembling the fronts yourself I'd replace the front strut bushings as well. As well as look into getting extended sway links and bump stops. But I'm a noon to this. I'm sure more experienced fellas will have more to say as well.
For the tundra coils I could find them new but they were $138 a piece. It's cheaper to buy the 881's or eibachs if I really wanted the height.
2001ATL
