Is this normal? 2004 V8 5speed
Kanab
When going down a long hill at say 50+ mph, if I put on the brakes the 4runner downshifts to a lower gear, which seems to make sense and help the braking, but I've never had a vehicle that did this before. Could be because this is my first 5 speed automatic. Any of you other 4th generation V8 5 speed owners notice the samething? If I'm going slower where I would be in a lower gear like 3rd or 4th, I don't notice any downshifting, only at higher speeds when I know I'm in 5th. With all this electronic control of everything it is hard to know what is normal and what is not normal. I know I have another 55K miles of warranty to figure it out but thought you guys would know. Thanks
Not a direct answer but from experimenting on a flat road, 45-50 mph seems to be about the speed where the transmission enters 5th gear (overdrive).
Happens to me, too. Engine braking sounds cool with my exhaust, so I dig it. Hope it's not a sign of some problem.
Glad to hear it's normal. Thought it was, but like I said, I've never had a 5 speed with this much computer control and drive by wire, with traction this and anti spin that. It should save some brake pads, which is fine as long as it does not wear out the transmission :)
Yup, normal. This is part of the "intelligent" aspect of modern trannies...also known as "grade logic" by many other manufacturers.
Nice. I know the sound you refer to. Which Dynomax do you have? I was thinking of swapping in a superturbo or even a ultraflow if it's not to annoying like the flowmasters....
The super turbo is just right for me. $120 installed. I have a buddy who just put a flowmaster 50 series on his, and I'm glad I chose te dynomax. Just my opinion! It's still a family oriented vehicle for me.
Mine does it but I realize to just tap the gas pedal and it upshifts and it will coat with no engine braking
Hey Pitbull you beat me. I had planned to start this thread.
Wonder if it uses a mercury switch to tell if your going downhill?
from the 2004 EWD, page 240
7. AI-Shift Control
The engine control module judges whether the road is downslope or upslope by detecting the throttle opening degree or the vehicle speed. Moreover it can expect the winding roads by detecting the turning condition of the vehicle. The engine control module keeps unnecessary shifting up from the fourth gear from operating and carries out the automatic shifting down to the third gear in order to control the vehicle running according to the road conditions. The engine control module also reads the driver's intentions during driving from his (her) accelerating operation and the running conditions of the vehicle. As a result of that, ideal shifting patterns [heh, in the manual it says patters] for each driver ar automatically selected without any switching operations.
hopefully, I don't ahve too many typos in there. :D
Kev
A very annoying trait of the transmission. I have this certain road i must travel on and it goes downhill right before a light. It bugs me to death. Pitbull you and I seem to have the same type of thinking on our cars! I removed the annoying chirp when you lock/unlock the doors last night, one more annoying thing thats history.
