Is this picture "pink milkshake" please?
Looks like red antifreeze to Me. Pull your transmission dip stick to verify your transmission fluid is at the proper level and not contaminated. It will literally look like strawberry nestle quick as an example. ;)
Sent from my SM-A505U using Tapatalk
Thank you, tranny fluid looks fine.
I'm glad I was just being paranoid, thank you for your response
If you haven't replaced the radiator in a long time, might be a good idea, just to be on the safe side.
Yes you should replace radiators every 10 years to prevent the milk shake. :)
No that’s no the “pink milk shake”.
You’ll know because the oil will make everything gooey and make one hell of a mess. If it’s ran that way very long, your transmission dies an untimely death.
20 years ago when Freightliner was building all the RV chassis they had a bad run of radiators that caused a lot of Allison transmission‘s to get pulled out of motorhomes. I think I helped swap out at least five or 10 of the damn things. Hell of mess when those two fluids mix.
Just change the radiator. It’s super easy. Easily the most simple radiator swap I’ve ever seen from cars,trucks, and semi’s. It’s only like 4 or 6 bolts and has its own built in hangers. Frickin awesome setup that Toyota put together. Hell of cheap too. Like $130 from the dealer. That’s only like 2-3 tanks of gas depending where you live. Even the AC condenser is cheap. Just change it all. You won’t regret it.
Even if you can’t/don’t want to wrench yourself, I highly doubt the entire job would cost more than 350-400$ for the radiator. Still super worth it.
Odds are your radiator is slightly plugged anyway from the poor placement of the Heater valve creating corrosion in the system by allowing a constant air bubble in the less than perfect systems. The only real thing I feel like Toyota messed up on on these rigs really.
Thank you all for your feedback. This site is truly wonderful. I do wrench myself on weekends & I'm going to take your advice and replace the radiator when I do the tranny cooler this winter after hunting season.
I've had my share of nice cars & trucks but the 3rd Gen T4R is by far the best built truck I have ever had - this is my 4th 3rd Gen T4R!
Thank you all again.
Airborne All The Way!
For reference (not my 4Runner) this is what it would look like in the radiator if you had a pink milkshake:
107432d1389385078-pink-milkshake-rookie-img_1258-jpg
DJNutshell
