Is this the antenna amp?
Probably a lot easier to fix behind the deck...My Kenwood had a power antenna wire that I wired to the amp...now I get better than stock reception.
Thank you guys, I was just double checking. I will let you know how it works out.
I have power/turn on going back there to my sub amp and popping off the plastic in the cargo area was easier than getting to my cd player.
LF
So after a couple broken clips and one remaining mysterious screw, this is not the way to fix the problem.
Larry, do you remember what the amp wire looked like? I had my cd player installed and didn't want to take apart the dash, but guess I will have too.
Yeah...there are two big antenna wires behind the deck and in the same "bundle" there is a third smaller black wire--that is the wire you are looking for...just give it power and your good to go.
