adio3x
Greetings all!
Just seeing if the Toyota Gods out there might have an answer for this strange issue I've been having recently. Basically whenever I start the ignition and drive for a little while, a weird series of events start to happen. First my head unit & hardwired radar detector reset. Then a few seconds later the dash will reset, sometimes all the lights come on and it seems like it it dies for a split second but then goes back to normal, other times the dash will just reset for a split second. Anyone else have this problem?
I have a 2010 SR5 with 145k miles. Running a dual battery with 2 group 31 Optima yellow tops. Checked all the connections at both batteries and they look fine. Voltage reads 13.4-13.6, both batteries have plenty of juice.
Did some reading, but couldn't find a solid answer. Some say the ignition could be at fault, others say alternator.
**EDIT** I was able to capture a small bit of what is happening. This was after it had already reset and all the lights on the dash lit up. Seems to happen in short bursts. Just a side note, the maintenance light is blinking cause of an oil change coming up. TPMS light has been on for 2+ years. This time it reset, the dash, the head unit, and radar went out at the same time.
https://streamable.com/u8hz4
Thanks all!
~Andrew
Thanks all!
~Andrew
