J120/J150 Platform: A Better Body Mount Chop?
BlackWorksInc
First off I want to clarify why I am posting it in the General Section versus the 4th or 5th Gen sections; it's mainly because this applies not just to one specific generation of 4Runner, but rather the entire J120/J150 platform family. Unless the Mods have a way to make "shortcuts" in the forum to link to one thread (i.e. you'd see the thread title in 4th & 5th Gen sub-forums, Tacoma, GX, and FJ but it would all link to one original forum vs. a half dozen unconnected ones; I don't believe I've ever seen that functionality in a forum unfortunately). So due to that fact I'd rather put it in General where it makes more sense, if Mods want to duplicate it and post it in the various sub-forums I'll let them do that.
So what is "J120" and "J150?" These are the platform codes for frame design that underpins many of our favorite Toyota off-road toys. The platform originates with the Land Cruiser Prado 120 & 150 sold over seas and is basis for all the following vehicle's frames:
-2002~2009 Toyota Land Cruiser Prado (J120 or sometimes called "Prado 120")
-2003~2009 Toyota 4Runner (4th gen, J120)
-2007~2009 Toyota FJ Cruiser (J120)
-2005~2009 Toyota Tacoma (J120)
-2003~2009 Lexus GX470 (J120)
-2010~Current Toyota Land Cruiser Prado (J150, or sometimes called "Prado 150")
-2010~Current Toyota 4Runner (J150)
-2010~2014 Toyota FJ Cruiser (J150)
-2010~Current Lexus GX460 (J150)
-2010~2015 Toyota Tacoma (J150)
*2016~Current Toyota Tacoma (J150, I have not seen any official documentation stating platform, but it appears to be a J150 frame with one or two minor changes)
Now you'll notice there's some overlap on a couple models that fall within that model's generation. The reason for this is because Toyota switched to the J150 Frame in 2010 for their line-up with no fanfare beside a cosmetic exterior refresh on some models (FJ & Tacoma being the obvious ones). The reason all you see is a mild refresh on these vehicles is because in terms of actual dimensions of the frames between the J120 & J150, they are dead on identical to each other. I've looked over the Collision Repair manuals for both J120 & J150 vehicles and there's almost no real visual difference (though the 4th gen frame drawings are slightly more simplified than the 5th Gen's so one or two non-critical brackets for like a plastic cover or what-not might be different). Supposedly the J150 Platform is "stronger" than the J120 with some inner channel reinforcements, but until I either see documentation stating where that's been implemented and/or cut aways of both frames, I'm just going to just assume those changes are extremely minor (almost all the new car features for the J150 platform vehicles talk about strengthening the body of the vehicle, not the frame itself; in fact very little to nothing is mentioned about the frames when looking at J150 vehicles "New Car Features.") This is why you can pretty much bolt on anything that fits on a 4th Gen 4Runner to a 5th Gen 4Runner's frame (hell you could literally swap the cabs on the frame and they'll bolt up perfectly fine), not to mention why suspension mods for J120 & J150 vehicles are almost entirely interchangeable between each other (think Tacoma or FJ coils, Upper Control Arms, trailing links, ect.) Now that you have a better idea of the frame that under pins your vehicle, lets move on to the purpose of this thread.
Now if you look around on the forum you'll notice a common mod that pops up for many of us who want to run larger than 33" tires on a J120/J150 vehicle, that mod is often referred to as a "BMC" or "Body Mount Chop." A common "flaw" of the J120/J150 platform is that there is a body mount that sits just behind the front wheels and is inline with the firewall (this section of the J120/J150 frame is pretty much identical on all J120/J150 vehicles); this body mount impinges on the wheel well slightly. It's not typically an issue with tires up to 33", but after that size under compression or turns the tire can rub against the body mount quite a bit; the most common solution is to simply cut the mount away and allow for more clearance. Now you must be asking yourself "why the hell would someone design it that way, can't they just move the mount back 2 inches and save us all this trouble? What a stupid design!" Well, this "flaw" is actually an extremely important safety feature inherent in the design of the vehicle and something many people over look when performing their BMC mod.
The second body mount is inline with the firewall because it is specifically designed to deflect the wheels and suspension components in the event of a type of collision called a "Small Overlap Frontal Offset". This type of crash is actually a lot more common in the real world as most people will swerve or try to avoid what they are going to crash into vs. hitting something at right angles like crash testing typically assumes. This particular testing has become more prominent and more important over the years because many "4 or 5" star vehicles did poorly in this particular crash. Here's a few pictures of the test as well as a video of a 5th gen 4Runner being tested to give you an idea off how this works in real life and what the purpose of the body mount is (pay close attention to the A-Pillar and Driver's Tire as it is deflected and how the 4Runner seems to bounce off the corner around where the body mount is located):
moderate-overlap-overhead.jpg~original
api-rating-image.ashx
So now you should realize that the BMC is basically removing a very important safety feature of the vehicle, so why the hell does anyone do it!? Well the answer is simple, we need to fit bigger tires and honestly we only need a little bit of space. The body mount actually sticks into the wheel well about 1" at the bottom outer edge, this is what causes the hang-up/rubbing under compression. Most people just cut the entire outer portion of the mount off, but really all you need is to notch it slightly.
My '04 4Runner Body Mount (It looks the same on pretty much every J120/J150 vehicle):
Pictures of a tire rubbing on the Body Mount and of a Body Mount already cut to allow clearance (notice how it lines up exactly with the edge of the wheel well now):
Bottom%20View%20-%20Body%20Mount_zpsn6ovfskb.jpg~original
After cutting the mount's integrity is compromised as you can tell because the supporting box structure has been cut away. This section of the frame is made of two different strengths of steel as shown in the following diagram of a J150 frame of a 5th gen 4Runner (due to the similarities and this type of diagram being a newer addition to Toyota's manuals I can't say if the J120 is exactly the same in all areas, but I am very positive that this is the rough layout of steel in the J120 frame as Toyota made a much bigger deal of improving the steel and design in the cab of J150 vehicles vs. the frame). Something else to point out is that many people will dismiss this as being relatively unimportant in the grand scheme of things, again I'd like to refer you to the video & pictures posted above as well as the frame diagram below, Toyota specifically reinforced this area compared to the rest of the frame because of this aspect. I also included a picture of a 3rd Gen Tacoma (2016 on our lot), as I mentioned before, looking at the frame it looks nearly identical to the J150 frame that underpins the 2nd Gen Tacoma; with one glaringly obvious difference. As you can see in the following picture, the second body mount has been reinforced and widened by about an additional 5~6inches of material, I imagine this was done because the previous mounts were shearing/bending backwards in offset impacts more than they should have been. But the point is that Toyota would not have wasted the time, energy, and materials to increase the strength of that one section if it was not a critical component.
151081d1427434861-5th-gen-body-mount-chop-frame.png~original
(The types of steel used in that mount section are AISI 1018 Mild/Low Carbon Steel (roughly 440MPa) & 1074 Hot Rolled Carbon Steel (roughly 780MPa; this post fleshes out the numbers a bit more: http://www.toyota-4runner.org/5th-g...e-body-mount-chop-2012-sr5-3.html#post1999103)
So what does all this mean for us? It means that when we perform a Body Mount chop on our vehicles we need to be very aware of what it is exactly we are doing and how it will affect the vehicle in all aspects (as we should be doing with all mods to begin with.) This means that while doing a BMC like the following pictures does give us the desired tire clearance, it does so at potentially higher risk of bodily harm in an offset collision.
72165d1348602782-body-mount-chop-img_0716.jpg~original
Now I want to make this clear, I am not trying to shame anyone at all with these pictures; it's about pointing out the different ways this mod is done and how we should all be thinking about all the aspects a mod can affect our vehicle. These are perfectly good and beautiful looking Body Mount Chops and they absolutely do exactly what they are meant to do; but in my personal opinion based on the evidence I mentioned above, these are cut down way more than they need to be and could pose an increased safety risk for the vehicle. So how should a Body Mount Chop be performed? Well, that's actually a very good question and the entire purpose of this thread; I have seen some ideas on body mount chops that retain a significant portion of the original mount and theoretically should retain the protective nature of body mount design itself, I also have a few ideas rattling around in my head on how to reinforce the mount while cutting away enough to get clearance. But I am by no means the authority or the man to set the standard, that's why I made this thread; to engage the community and garner ideas and alternative methods to create a "Better Body Mount Chop" to create a more unified and safer mod that we can share with everyone and feel safe doing.
I'll leave you with this idea I came across on a Tundra forum I thought was very creative and interesting:
pieshapes-jpg.2309
~original
[This is for our Current/Finalized "Better Body Mount Chop" design]
Design Goals/Desires Characteristics:
-Gain Clearance for 33"+ diameter tires
-Keep the amount of material cut from the Body Mount to an absolute minimum while achieving maximum clearance (essentially cut it slightly behind the edge of the wheel well/body)
-Reinforce the removed section of the Body Mount with similar steel as the original to retain maximum strength and potential protection in a crash.
-Possibly reinforce the body mount from behind like thee 3rd Gen Tacoma to further reduce the chances of the mount buckling/shearing under impact.
A bit surprised not a lot of responses on this.... [MENTION=66316]1engineer[/MENTION] [MENTION=96008]Engineer[/MENTION] [MENTION=106176]wfo9[/MENTION] [MENTION=78273]Jeremy556[/MENTION] [MENTION=49649]KidVermicious[/MENTION]
Come on guys, don't fail me now! Nerds unite! :D
Fantastic research.
I've been in on two body mount chops (I didn't do either of them, I was the guy hovering and holding tools). One of them was done the standard way, which was to torch off the leading inch or so of body mount, trim back the piece that was cut off, and rebox the mount with it. The other was very similar to your last pic there, they took a wedge out and beat the outside back until they could weld it shut.
I don't think the BMC is as big a safety deal as some are making it out to be. No doubt that Toyota engineers designed that feature very carefully and it plays a part in keeping the occupants safe, but I'm driving around in a thirty year old truck that wouldn't just flunk the small offset frontal crash test, it would rip it up, swallow it, then strip naked and dance on the teachers desk drinking Jim Beam and hollering The Doors songs until the police arrived. And I'm good with that. I think it's a personal call, I think it's very good for folks to be aware of all the ramifications of any modification they make to their truck. I think it's good for an owner to think to themselves "do I really need 33 inch tires to get my truck to go where I want it to go, or is this an image thing? And if so, is that image worth compromising this safety feature of my 4Runner?". Personally, I wouldn't even consider it for image, and I wouldn't hesitate if I was using the 4Runner like a 4Runner and needed the increased tire size.
Regarding a "better" way to do it - I don't think the amount you cut off the front matters. It's weakened and that's that. You could definitely plate the top and back to add more strength, but is anybody sure that the BMC itself really is that terrible, and are we sure that reinforcing a chopped mount wouldn't have some other undesirable side effect? Does anybody have the chops to do some modeling?
Good discussion.
I don't venture into the general discussion section much...
I agree the BMC is a concern... but the reality is that once you modify the truck for more hard core off-road use, all bets are off in terms of exactly what will happen in a high speed collision scenario... Running an aftermarket bumper/winch plate completely changes the safety of the vehicle. Running sliders is also going to be a factor in several scenarios. I won't even go into the roll over issues that a lift introduces.
In summary, there is so much to be concerned about that there is no reason to pretend anyone knows what all the risks are. It would take very expensive testing and simulation that will never happen. You just need to know it is no longer at OEM safety levels. You might luck out, you might not.. But it's still a pretty safe vehicle compared to what we all previously drove a few decades ago.
For the BMC specifically, cut as little as possible and reinforce as much as possible. I'm not that worried about it, but I do very unsafe things on a daily basis ;-) You have to live. I try not to be stupid... or dismiss the obvious, but I also don't worse case scenario every little detail.
There is probably a really good solution, but I'm not sure sure the typical cut and weld in a plate is all that bad either. I feel pretty confident in what I did. It sure looks OEM ;-) Just don't think the juice is worth the squeeze at this point.
[MENTION=66389]BlackWorksInc[/MENTION] Very good write up and you hit the salient points well. In this litigious society we currently live in safety is every manufacturer's middle name. [MENTION=49649]KidVermicious[/MENTION] had a good point insofar as when the body mount is cut, even a little bit, all bets are off as to the strength. Specific heat treatment is one of the major differences between the different strengths of steel and when you take a torch to it you definitely weaken it. The body mount was designed that way to deflect the tire, rim and suspension components away from the passenger compartment. When you do ANYTHING to the body mount, Toyota will wash their hands of any liability. Is this body mount important? Look at the video above and decide for yourself.
With that said and you WANT (not need) to run big 'ol tars you will have to cut it. Again, anytime a torch hits that steel it will change strength and make it much weaker. Can you reinforce it on the back side? Sure you can. Get a piece of 1" plate and start welding. 50 lbs and several hours later you have reinforced it. Will it be good enough? Maybe, maybe not. As far as running a simulation on your work? There's a reason they crash test the vehicles for real.
So make a choice and live with it. Back in the day I used to hack up my vehicles in the name of "improving" them for off road. By the time my wife and I had children (daughter is now 23 yo and son is 20) I had finished college and was designing off highway equipment as an engineer. I quickly learned that my mods I did back in the day were pretty sketchy from an engineering standpoint. Again, do what you want but this thread will make sure you do this mod with a bit of knowledge.
In terms of the body mount being a critical structural safety feature, I am almost 100% positive that is it's main design in that particular location vs. it's secondary design of being a body mount. Looking at various Hilux, Tacoma, 4Runner, and J120/J150 frames over the years (to be honest this thread came about from some research I was doing in Toyota BoF vehicles, particularly the mid-sized SUV/Truck area) the evolution of that mount from a very small stubby thing, to a longer, angled, and stronger piece is less to do with supporting weight and more to do with managing that deflection. As you can see in the videos and pictures, on the current frames it's sticking out to the very edge of the cab pinch welds. I'm not saying that a BMC is a horrible mod or that cutting so much is going to just outright kill you; just that many times I see people taking far more material than they really need out and not effectively reinforcing what they have cut out.
Now, there's something interesting that you guys have pointed out that added an interesting wrench into the mix of my mental simulations of various cuts/welds at that mount. While I was aware of the different mods affecting safety and to be honest ignored most of them for focusing on the body mount in particular (I figure the lift, bumpers, sliders, and such are obvious enough in how they affect the vehicle's safety features that there's no real need to make a thread regarding it as well as they for the most part won't do much to mitigate and/or change the particular type of impact we're talking about... but then I again I could be assuming that what's obvious to me is obvious to everyone again...)
-I did not account for a cutting torch being used to trim/cut that mount. I had assumed either a bi-metal reciprocating saw blade and/or a grinder with a proper cut-off wheel would have been used. Utilizing a cutting torch could easily result in weakening the temper on the 780MPa portion of the mount (the 440MPa portion I wouldn't be worried about as it's pretty much run of the mill mild steel anyways.)
- [MENTION=49649]KidVermicious[/MENTION] mentioned bumpers and other features, this got me thinking... Since many of us use Full Metal Bumpers in the front, this alone could greatly offset the risk associated with cutting down that particular body mount. The bumper could theoretically deflect/absorb much of that offset impact in a way to reduce the push back seen in the videos (granted there's other issues that come up, but in regards to this particular area we are focusing it seems a plus.)
-Additionally looking at my pictures more I realize that my Sliders actually almost meet the mount at a right angle (My sliders are a hair shorter than I'd like, I actually pushed my fender up slightly because there's a 3~4inch section from the wheel well opening to the slider that isn't protected and on a muddy day it slide on a rock just perfect), You could possibly tie the mount to the slider (if you had weld-ons) since the slider is for all intents and purposes an extension of your frame... an interesting possibility.
- [MENTION=66316]1engineer[/MENTION] To be honest, I also overlooked the fact that many people are probably just welding half hazardly whatever scrap they have on without really trying to control the HAZ (Heat Affected Zone) or strength of what they are welding to. It seems obvious to me, but that's more because of my experience with welding and machining than most people. Though welding the 780MPa shouldn't be too much of an issue since it's thickness is not that great; pre & post heating wouldn't be as important since workable temperatures could easily be reached with a MIG set-up, at least according to a quick search on welding properties of the 1074 HRCS I mentioned above.
I realize most people are going to just cut it up how ever they feel is right regardless if I had absolute proof they were doing it wrong rather than some strong reference and inferred data. Not to mention to accurately test how various versions of the BMC affect the safety of the vehicle and how various corrections could repair that issue would require a ton of money and testing than is really worth bothering for. Yet, I think we have a good amount of data to look at in that respect, using the OEM section of the frame in that area as a Control; after all we have the metallurgy, angles, dimensions, and even crash testing videos to understand how it works and is built. Using that control data we can extrapolate a rough estimate of how to correct and/or reinforce that section of the frame to near OEM or better as a result with a reasonable amount of accuracy even without expensive testing (considering some of us are engineers and have experience in fabrication, design, welding, ect. that would only further help us work with what data we have to come up with a good design that should meet that control data; granted some variables will elude us without testing, but I think being slightly conservative and slightly overbuilding the reinforcement should help mitigate much of that).
Also I figure if we as a community came up with a "standard" that could be presented to members as a more correct/better way of doing the mod so that it's as safe as can be while gaining extra clearance tires; then we should promote that way of doing the mod. I mean sure, most members will probably never get in a serious enough accident where it's an issue; but assuming one did and doing it the more correct way is the difference between getting out in one piece or the cab crushing their legs... I'd feel that's reason enough (to be honest it almost feels like an obligation as being part of the forum community to promote good modding practices and methods for those who come to us seeking our expertise and experience.)
I know I'm coming across a bit preachy and mushy here, but forums helped me a lot when I was younger and less skilled in the trade; not to mention I have met many people and heard many stories where "oh this guy on the forum told me to do it this way" and it was just absolutely wrong... in some cases so wrong as to actually be putting the occupant in potential danger because they got incorrect information from a place where they figured they'd get good information.
I thought I posted a reply yesterday... but guess I never hit the button....
I can't imagine cutting the body mount with a torch. It would melt the upper body mount bushing. Most people use a cut off wheel or a swazall with a demo blade. Even a plasma cutter would be very difficult to position and avoid melting...
Welding it back up is also tricky, You have to stitch weld several passes to avoid any melt on the bushing.
What is being overlooked here is what a PITA this modification is (when done in place)... If you pulled off the body, many options would be opened up. But trying to do it in place really limits what you can get at. Pulling the body would be another one of those "juice not worth the squeeze moments".
There are some deceiving images in the first post. The impact point in the video is only a few inches (~10) inboard (much different than what is shown in the topview image just below) The key is that the frame horns are completely missed.. and the test has been modified to maximize damage on a body on frame vehicle. The stock aluminum bumper wings would just fold up in this scenario. An aftermarket plate bumper setup would completely change that equation. Not sure if it would be better or worse, but I'm guessing it would deflect the vehicle putting it into a spin.
I'll reiterate again, IMHO the COG change is the number one safety concern with a heavily modified vehicle. Every major impact is going to send the vehicle up and eventually over. And heavy aftermarket bumpers will most likely magnify this behavior. Then you have over landing gear like a RTT...
Interesting how Toyota has made the body mount massively larger on the new Tacoma frame, obviously to improve the small overlap test. As mentioned, the frame attached slider will probably fill in for the weakened body mount. I imagine a steel bumper will drastically change the outcome of such a test, most likely sending the vehicle sideways, negating any small overlap vulnerabilities, but likely inducing a (probably much worse) roll over situation.
Just like every modification, what you gain in one area, you lose in another.
I will comment, from an engineers standpoint, I guess 34 years as a machinery engineer gives me the appreciation of your write up...
First of all, one of the few post that I read word for word, excellent write up.
When I see vehicles running down the road with excessive lifts, tires and other mods, the first thing I think is, not designed for that. In my line of work, not different than any engineering field, changes are usually made under a MOC guideline, Management of Change, a process that mandates all changes are evaluated from a safety, fatigue, operational and maintenance standpoint, impact to these areas are evaluated before a modification is made. Bottom line any change can and will have an impact, how much are you willing to accept becomes a risk analysis and acceptance.
My 2015 will stay just as it left the factory...if I need bigger tires, I will get a RAM truck...
Thanks for the write up.
77
Oh no, the thread stopped :Cry:
I too was reading the thread, word for word and found everyone's points very interesting. I was hoping to find the end result of said research so I could perform the 'better' body mount chop next weekend.
There really is no reason to continue. This is a rather detailed warning as to what some of the consequences of a structural change could do safety-wise.
In the days long ago when I was an engineering manager I would get many ECRs (engineering change requests) from the manufacturing manager for things to make assembly easier; from the machine shop manager to make machining simpler; from the accounting manager to make things cheaper.
I would then have to expend a lot of mine and my engineers time researching to see if the ECR had any real merit; would actually improve the product or would just mess things up. Probably 80% of all ECRs were rejected - and would not become an ECO (engineering change order).
Now for my gut feelings on BMC (body mount chop):
1. The 4Runner stock has very tall and wide tires compared to the 4x4s I have run in the past. In fact my '04 LR Discovery came with 29" tall tires. I changed to LT265-75-16s to just come up to the diameter we have on our stock 4Runners.
2. I think even going to 32 or 33 inch tires is a waste of effort. Only if I were going to be a professional rock crawler/mud bogger would I bother with such a thing. And even then I would do it on some old, very modified
rat rod that would never see a highway.
3. On this forum I do believe that 99.9% of the members do not and never will need bigger tires. It's all for show.
BTW: Thanks to all of you who have discussed this thread; a lot of good information here.
My only question in the BMC is: Is there any point to welding the plate on after making the chop? Clearly the inherent safety benefit of the BM location extending beyond the body is negated once that extension is removed. Welding in a plate couldn't possibly be as strong as the original steel.
The other body mounts on the truck are not fully enclosed. Is there any real reason to weld the plate on after the chop??
It probably wouldn't hurt to reinforce it, welding a plate of similar steel wouldn't hurt if done properly. That being said many people haven't (I keep putting it off) and it hasn't hurt anything.
pieshapes-jpg.2309
~original
Being an engineer myself...
I can tell you that most engineering is really just people trying not to get yelled at. You would be surprised at the number of engineering changes that are made in my industry simply to make it look like someone was doing some hardcore engineering, when in fact they just decided that it would save $6 in manufacturing costs to simply move a piece of material from one location to the other with absolutely no mathematical testing or analysis. I find your post to be based on outsider non-information, with no hard numbers or mathematical analysis or test data. For all you know, the addition of metal you describe could be nothing more than having some extra Lexus parts laying around that Toyota needed to find a use for. Assigning any type of reason for a change made by another person without knowing what they were supposed to accomplish is foolhardy at best. The fact is, nobody on this forum has ever spoken to or engaged one of the Japanese engineers who designed this frame or seen any test data on what specifically this piece does or does not do. We are simply unable to make any conclusions on any part of anything relating to this piece or that piece or this design philosophy without being 100% wrong all the time.
I actually get quite a laugh at people on forums "reviewing" my own integrated VC hardware designs and trying to determine what I was doing and how "the designer" must have "been thinking x or y" when he (me) designed this product feature or deleted this part of the program because of some completely left field thing that I really wasn't thinking about at all.
Bottom line is that without any conclusive test data performed with instrumentation that is not accessible to normal people, we are unable to say with any certainty that this body mount modification has made the vehicle less safe, more safe, exactly the same or we have inadvertently created a giant rolling banana that is more advanced than a space shuttle.
I agree with most of what you said. I have talked to a Toyota engineer when he was visiting from Japan for a different reason at my old dealer. As well as one or two guys at our regional office who deal with engineering decisions and work with them in regards to vehicle issues and design. The expansion/reinforcement of the second body mount to better control an offset collision is something I'm fairly confident of based on the information I have heard and collected. It's grown substantially over the course of the development of Toyota's ladder frame design and as offset collisions continue to become a more common testing method/standard it makes sense to reinforce that section.
I would love hard data to be honest (particularly in frame construction between J120 & J150 since they are so very similar measurement wise but they claim reinforcement in the J150 platform). You're right a lot of this is speculation and assumptions based on limited data I was able to scrounge from various sources. But it's the information I have available based on impact tests, engineering information, industry standards for safety, Toyota's current trend (that's tricky in itself to predict), and such. I'm not denying the possibility, but for the most part a lot of the information I found and collected on my own through various channels (including Toyota's internal systems) seems to line up with what I am presenting.
If I could get more detailed information I would jump on it, I personally would love to have the reams of engineering data and such on the 4th and 5th gen 4Runners for my own personal curiosity and for planning modifications. Unfortunately I haven't found that yet. :(
Since you are a tech at a Toyota dealer, is it possible to put in a request to Toyota corporate for some info about that piece and maybe get an engineer to tell you what the story behind it is? Just thinking out loud. Maybe you could say that you have seen a lot of people chopping that part off on trucks that you get in and want to know more about what the consequences of removing it are?
I know that I used to tell people who asked me why "X" was changed from the previous rev. if it was someone in my corporation asking.
I have tried to find the "appropriate" channels for that, but they don't seem to exist on the technician end unfortunately. Which is a bummer, I tried emailing corporate about this and another topic and I just got a generic customer-oriented response despite prefacing my position in the company. Toyota's an odd company sometimes...
[MENTION=66389]BlackWorksInc[/MENTION] (et al) interesting and thought provoking thread. Thanks for the good discussion on this.
DJNutshell
