hydrolic Jack / Stands for DIY work
OK, my 4rnr recently passed NY State Inspection. I don't think the dealership did much, except take off the wheels and inspect the pads. But, in doing so, they said I was down to 15%-20% pad material left. I'm currently at 36K miles, and I figure, that's probably normal for someone with an agressive driving style.
The weather has gotten a bit cold in the northeast, and since I'm trying to avoid the cost of the stealerships $400 brake pad service (I'd like to get it done before snow is on the ground), I wanted to know what kind of hydrolic lift you all recommend/use. Will a 2 ton or 2 1/4ton jack work, or should I aim for a more sturdy 3 ton jack.
How high should the jack reach? Would you get the ones with wheels/castors or are the stationary ones just as good.
I'm in favor of the stationary ones sears 4 ton because their cheaper and lighter to deal with. They don't take up as much space in the garage, and would probably serve the purpose well. Thanks for any insight you can shed.
