JBA Upper Control Arms with Stock 7" Wheels without wheel spacers. Anyone?
propain
Hey,
I have JBA UCA's i want to install with my TRD Pro 7" Wheels. Does anyone have this setup? Any rubbing? I want to avoid adding wheel spacers or buying new rims right now. I called 2 shops to install the UCAS's and told them about the spacers, and they both said dangerous to add the spacers. Want me to sign a waiver.
I'd like to install them without the spidertraxx wheel spacers but dont know if they are going to rub. Right now im running Camburg UCA with no rubbing and no wheel spacers installed, tires are 285/70/17 Firestone Destination M/T2 on TRD Pro 7" Wheels.
I have the JBA High Caster UCA’s with 275/70/17 Falken Wildpeaks and rub when near full lock and under load.
I'm looking into the same arms for mine and I believe they specifically say that won't work unless you run spacers with a 285. I'm running spidertrax spacers on mine currently with stock trail wheels and have for about 5-6k miles. No issues whatsoever. A lot of shops are sketched out by spacers though. If you install them correctly with loctite and a torque wrench you would be fine. But no telling if a shop will actually do that unless you watch and know what you're seeing.
Hey,
I'd like to install them without the spidertraxx wheel spacers but dont know if they are going to rub. Right now im running FCamburg UCA with no rubbing and no wheel spacers installed, tires are 285/70/17 Firestone Destination M/T2 on TRD Pro 7" Wheels.
ever get this worked out?
AndiGarage
