JBL 6 Disc won't switch to SAT input!!!!
esb_t4r
Member
I have a 2007 JBL 6 Disc changer with an iSimple iPod adapter attached to it. The iSimple has worked fine since I bought it but ever since I tried hooking up my 3g iPhone to the radio, the radio has been having problems switching to SAT.
Not sure if the iPhone has anything to do with it, because when it was working it was playing music from the phone with no problem. It seemed like if I cycled the ignition on and off it would work. But it has stopped switching altogether. Every other function on the radio works fine.
I don't think the problem is with the iSimple adapter since when I plug my normal iPod into it, it still charges fine. (The radio won't switch to SAT with it plugged in.)
Has anyone ever heard of this problem before???? Is there a way to reset the radio to fix the problem???
Puhleeeeeeze help! Thanks!
-ERic
I have come across something similar to this. My satellite radio will not function if the radio was turned off.... Prior to starting the truck. I can push the a.m. /sat button as many times as I want it just stays in a.m. mode.
If I leave the radio on then turn the ignition off, wait 30 seconds and restart the truck, Everything works.
This has not been a big problem for me as I leave the radio on 99% of the time.
Good luck
30/30
Good luck
30/30
I tried doing this on Saturday to no avail. However, I did turn the car off with the radio on, and did not start the car up again until this morning. Much to my surprise the radio switched to SAT and I was able to use my iPod. I didn't try my 3G iPhone yet....guess I want to see if it continues to work for awhile before trying again.
Really weird problem :|
