Jerking when switching from Reverse to Drive
Mano1124
I have a 99 4Runner 2wd and i'm getting a jerk when i switch from reverse to drive and back to reverse. I thought it was the u joints needing regreasing but when i went under the truck the u joints has no zerk fittings. So, i raised the rear and turned on the truck and put it in reverse and noticed the left rear tire spinning. I adjusted the brake to where it was hard to put back the drum and it still spins for a bit and it stops. I don't want to adjust it to the point that the left rear brakes more than the right rear. Any ideas? I also noticed that i can move the shaft close to the tranny pan up and down. Do i need a new tranny mount?
tuṣṭāva
