JetChip Programmer
I do believe the Jet chip will give you some power, but not as great as an APR X-1 or Unichip. Computer will eventually compensate for the Jet Chip parameters, where as an X-1 is a stand alone that will give you ultimate tuning control.
It depends on how the 4Runner PCM/ECU is configured. If it is possible to replace the factory profile with one from the 'tuner', then the computer will never compensate or over-ride the tuner's settings since they will become the actual profile by which the PCM operates the vehicle's engine/settings. This is why "Step 1" on all these types of tuners is *Back up the OEM PCM settings!*
If the 4Runner's PCM does not have the ability to accept and retain post-factory profiles, then replacing the entire PCM with a "tuned one" is the way to go. It is my understanding that the APR X-1 system is one that replaces the stock PCM with an APR-tuned one. That's a whole computer swap, not a temporary tune.
I haven't had the urge to tinker with the 4Runner, mine's plenty powerful enough considering that any increase in power is normally accompanied by a proportionate decrease in fuel mileage - there's no such thing as a free lunch. But I did have a 2006 Chevy Colorado for a while, and in an attempt to sqeeze a few more HP out of the meager 3.5 L5, I swapped the OEM PCM with a tuned one...it did help power. It also did cause a slight dip in MPG. All and all, it wasn't worth the money or time it took to do, certainly when you factor in the time to get your ECM reprogrammed if you can't find a tuner that will ship you a new one at the same time you ship your OEM PCM to them to use as a "core" for another customer later on.
Not true, the APR does not replace the factory ecu. The factory ecu ouputs into the APR where it then does it's job. It is designed not to upset the factory ecu and it's control over essential functions like the I.C., drivetrain, etc.
http://aprpower.com/ECU_mainpage.html
Please read more about it at this link. You'll get a better idea of its potential rather me explaining it.
Now granted, it's not a cheap way to go, but it's definitely the ultimate way to go as far as tuning goes.
there has been much debate over the use of chips/programmers, on the 4runner. all i can say is, after the borla exhaust & cai install, it seemed to loose some low end grunt, so i got a unichip, installed it, reset ecu,& was happy it gave me back my low end + a little extra. so i could now get full use of the previous mods. the chip was programmed exactly for these, (thats the only way to see any worthwhile results) & worked great for awhile, then little things started popping up, at first , dash lights going on, then, some sputtering, then stalling out while driving! each time this happened, i would reset, & it would be fine for about 2 weeks, then start all over again.to me, it seemed to have problems with other electrical things like , (aftermarket remote start, changing to a different air filter, hi-flo MAF, etc.) so after many resets,( the co. states all these things could cause the chip to go bad) i got fed up & removed the unichip, & modded the volant to be a true cai. & havent had any problems for months , also the modded volant seems to give me the same if not better results the uinchip 2 did. moral to the story is, in my opinion, dont waste the 600+ on a unichip, im not sure how the other devices will work,( also tried the venom 400 on a jeep, that is wired in like the jet chip, not much good either) but i wonder if they would fair any better. if you get better throttle response, +10 hp for 300 + dollars, & like it, then i guess its worth it for you, but better pickup usually leads to less mpg. that said, the jet programmers have gotten decent results on diesel & other makes of vec. & i have gotten good somewhat decent performance from them in other vec. ive owned, but from what i know now, theyre just not worth the $.
Trdoffroad916
