JL Audio Stealthbox
funk_drum
Does anyone actually HAVE one? A lot of "try" it threads. I have an 02 Limited and want the Stealthbox. Thinking of building something 'stealth' as an amp rack on the left side too.
Thanks!
I have on in my 01 tacoma s-runner. it had a 10w0 and it sounded ok, then put a bigger sub (more power handling) then it wasn't enough air space. I have since put a smaller sub (not JL) and still sounds very good. it can still pound very hard, but if you want more of a 3 12" sub sound, then you might want to try a different sub box.
I just want the box. I have a different sub that needs only .65 cu feet and I think the stealth box is about that. Just wanted to see how it fit/sounded.
Is this stealthbox easily removed? Because the 2decker cargo shelf is rendered useless when the stealthbox is installed. I'm wondering how easy it would be to remove to regain access to the shelf, if needed.
