JL HD900/5 Amp
PhdNPrerunners
I have a JL HD900/5 for sale. I have had this for about 6 month and bought it new from Car Toys. I really don't want to sell it but I need money so I can get a Macbook Pro for school. This is an amazing amp that takes up barely any space. This will be the cheapest you will be able to find this amp. I take really good care of my stuff just like it did with this amp. Looking to get $650 for it. I also have a couple of Focal amps for sale also, Text me if you are interested (832)472-4272 Also will trade all amps ($2500 worth)for a 15"+ Macbook Pro Unibody. Here are specs on the amp
* 5-channel amplifer
* 100 watts RMS x 4 at 4 ohms + 500 watts RMS x 1 (at 1.5-4 ohms)
* 75 watts RMS x 4 (at 1.5-3 ohms) + 500 watts RMS x 1 (at 1.5-4 ohms)
* 150 watts RMS x 2 bridged (at 3-6 ohms) + 500 watts RMS x 1 at (1.5-4 ohms)
* variable high-pass filter on front and rear channels (50-500 Hz, 12 or 24dB/octave)
* variable low-pass filter on subwoofer channel (50-500 Hz, 12 or 24dB/octave)
* subsonic filter on sub channel (24 dB/oct at 30 Hz)
* removable power and speaker plugs
* optional wired remote for level control
* Class D amplifier design
* MOSFET power and output stages
* differential-balanced inputs eliminate noise from your vehicle's electrical system
* preamp and speaker-level inputs
* preamp outputs
* 4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier
* no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
* 10-3/4"W x 1-15/16"H x 8-5/16"D
5 channel for trade + cash?
Bump $600. No body wants an awesome compact amp?
This is exactly what I need! 1 amp to push my whole system!!!
I posted on your previous AD about my MAC BOOK pro. Not sure if that is the one you are looking for.
Let me know.
-Ambush
