Just a heads up yall.
Personally this stuff scares me on some of these bumpers. The whole point is for protection and exposed lines like this make me nervous.
I was looking at getting one of these a few months back but they unfortunately do not offer a body-lift option. Hint hint, I sure wish they did...
On a side note does anyone running a body-lift have one of these installed? If so how did you compensate for the large gap?
Doesn't concern me at all, the chances of something hitting those lines are very slim. They're tucked up high and the only way I can think it would be an issue is if you try to climb a jacked rock with a 90 degree angle that your tires won't clear. Even then, the skid plate would hit it first, unless there are pointy objects sticking out. I added fog lights right in front of those lines because I don't feel I need to worry about the lights getting damaged there.
I have one, there is almost no gap when you put it on a truck with no body lift. In fact, I added a half inch body lift to get a little gap for some room. Check my build, I have pictures of before and after the body lift. I'd post some here but not near a computer right now.
I guess I should state that if I didn't have bad luck I wouldn't have any luck at all. I'm more worried about a branch or something catching it.
