Just bought an E7007
horn34
This is going in my 06 non-JBL Limited 4Runner. From dchay's thread it appears that I need the following for the install:
C0069-33007-W1 5 Pin Wire Harness $6.00
C0069-33010-W2 AUX and SW Harness $45.00
C0069-33020-W1 Non-JBL to JBL Harness $48.00
08663-00340 GPS Antenna $70.00
C0069-000G5-W1 Reverse and Speed Harness $5.00
JBL amp
Does this sound right? Anyone have experience with this kind of install?
I don't see anything for the bluetooth. I believe the E7007 HAS it.
Correctamundo. If you want to use the Bluetooth, you will also need a microphone, and the 24-pin connector for the nav radio which also has the rear camera input as well. Oh yeah, I also added the right side steering wheel switches when I did the mod. This adds the buttons for using the Bluetooth, however, there are ways around this.
Another thing, If you want to save $35 - $40, get an Eclipse GPS antenna. It's the same antenna and costs a lot less.
Installed my E7007 last year. List looks good, you'll also need a map DVD if it's not already included.
I got the microphone from: Carson Toyota TRD Parts, Replacement parts and accessories for Southern California
Part number for the 24-pin connector: 90980-12404
Right-side steering wheel controls: 84244-35030-B0
Steering wheel ribbon (connects right to left): 84204-58010
I believe they make a Plug-and-play connector for the microphone, also available from Canada, but I don't know the part number for that. I ended up wiring it myself.
Backup camera can be connected to the same 24-pin connector as the microphone.
JBL amp
Does anyone know where I could get all of these parts?
Also, is there some sort of manual or has anyone made any type of instructions for this install?
The part numbers that are mentioned above you can punch in www. partznet.com (discounted OEM, click on Toyota and go from there). The part numbers that begin with a "C" are from Toyota of Canada, however they are NO longer available......... I'm a semi-novice when it comes to electronics, so because the wire harness is unattainable, I'm looking at crimp-on snap connectors (radio shack Catalog #: 64-3085) to connect the wires to the head unit. Picture on the bottom......I'm looking to connect the male connector (in the pic, its chrome) to the pins in the HU. These "slip" onto the pin, but I'm trying to find a method to adhere it (no solder).....:confused:
As far as the install.......do a search and you will find A MEGATON of info.....hit the search button and type in E7007...
Hope this helps ya!
I have Toyota Sienna 2010 XLE Limited edition. This car has
JBL system installed.
Steering Wheel Bluetooth controls for phone only
It has radio controls on steering wheels
It has roof DVD entertainment system.
What my car does not have is
It does not have Bluetooth media player
It does not have build in navigation system
It does not have Rear view camera
I am looking for replacement unit that has navigation system, USB input, blue tooth media player and can control steering wheel buttons and roof entertainment system. Can you please suggest if E7007 will work for me? If not which model will work for me?
