TRD04RUNNER
All I did on the 30K maintenance was lube my drive shift, change my ac filter w/ a home air filter, rotate the tires and check the psi, top off the fluid,spark plugs, change the oil and filter .
When I took out the plug I check the gap on them and 3 Denso plug was gap at .43 and the other 3 NGK plug was gap at .48 from the factory???? any of you V6 4R change your plug notice they were gap at the factory different on each side??
Anyway I just save a nice chunk of change doing the 30k myself instead of letting the stealer do it for $375!
now with the extra $$$ I save I can get myself a nice Xmas gift like some 06 LEDs tail light for my 4R!
It was a easy 1 hour and 15min job out in the cold and it only cost about $60 for the parts! after I install all 6 NGK plug gap at .43 I fill up the oil (5.5qt of Mobil 1) I took it out for a little ride and notice that it run and idol a lot smoother them B4 and has a little extra kick @ 1500 rpm I never notice B4! I hope my MPG get a little better too ! we'll see when i take her on a long run to work tomorrow!
