Just introducing myself
RonMAIDEN said:
I simply just have bigger tires otherwise it's all stock and there's plenty of trails that are stock friendly but even a stock 4Runner can go pretty far.
Good to know. :)
Made the drive to Albquerque, NM there and back in 1 day (my girlfriend and I are exhausted) but I LOVE this truck.
The hood and roof have some oxidation on them, but hell for the deal I got, I don't mind.
EDIT - Here's a quick pic I just took out in the garage with my cellphone. You can see my other blue pride n' joy on the right :)
1217082338.jpg~original
welcome Matt, and Congrads on the Runner, I miss my 99..
Theres sooo many "stock" friendly trails close, and with a good spotter, that thing in stock form will go places that will suprise you.
Id do the "grey wire" mod, and Diff, breather mod if your gonna wheel, :D
just to clear it up, all 3rd gens are shift on the fly 4wd. the 99-00 limiteds and all 01-02 had push button 4wd which has a button on the side of the 4wd stick. also, all limited came with the automatic trans.
i've got a 97' limited with push button. so does my friend with a 96' limited.
this is from J.A.'s 4runner history page
"Introduced in 1999, Toyota's multi-mode 4WD system is standard on Limited grade models. The multi-mode 4WD feature is actually a full-time all-wheel-drive system with 2WD capability. The all-wheel 4WD mode may be used in normal driving conditions on all types of roads from dry, hard surface roads, such as pavement, to wet or snow-covered roads. Driving with the multi-mode's all-wheel drive system engaged provides the driver with a more sure-footed feel because power is applied evenly to all four wheels which improves traction.
To switch from 2WD to the all-wheel 4WD mode, simply reduce the vehicle's speed to less than 62 mph and push in the One-Touch "4WD" button located on the front drive control lever knob (on the transfer case the all-wheel 4WD mode is indicated as "H4"). Returning to the 2WD mode is just as easy, depress the "4WD" button once more and the vehicle is again operating in 2WD. "
It is my understanding that all 3rd Gens had that push button to engage a mode of 4 wheel drive. From 99 up that mode changed. It became a full-time all wheel drive like J.A. explanes.
My 1996 had a "J-gate" style shifter that had H2, H4, N and L4. It was an SR5, so it didn't feature the one touch select that J.A. mentions on his site. Here's a quote from the 1997 page:
"All 4WD 4Runner models are equipped with Toyota's 4WDemand shift-on-the-fly engagement system, allowing the part-time 4WD system to be engaged at speeds up to 50 mph. 4Runner Limited models are fitted with a One-Touch Hi-4 switch for push-button 4WD engagement. On all models, the transfer lever is used for shifting from 4WD High to 4WD Low."
tuṣṭāva
